David Neibert
SCCoA Admin
I've heard a few people mention using a 6G alternator on an SC. What does that alternator fit (what car/motor) ? What needs to be done to the wiring and mounting on my 91 ?
I believe you would need to upgrade the output from the alternator significantly. I highly doubt the stock wire is up to handling the amperage that a 6G can put out. I would upgrade to 6gauge cable.
I want to upgrade my alternator now that I'm likely to have a bunch of fans, a pump, snow system, fuel system etc... plus a decent radio.
To fit the 6g alt just do what 3.8 Mustang guys do to fit their alt onto the SC Brackets. Just some grinding of 2 spots to accomodate the larger size of the alt. The mounting points line up well with just a spacer or 2 needed on the top mount.
Make sure you get a 6g out of a 02+ 3.8 mustang as that one is sure to work and grab the pigtails out of the donor car as well.
I can't speak to what wiring to change because I just used my stock 98 alt in the SC bracket so no wiring changes were necessary.
>The output from the 6G is only 130 amps
At idle under full load, sure...but we're talking about a 200 amp unit.
Mike is correct - 10 GA wire/cable as an example is not large enough to handle 130A in an engine compartment. A wire swap to 6GA is a common mod, written up frequently when adopting this/larger alternators to older/other cars.
One example: http://www.fordmuscle.com/archives/2004/07/6GAlternator/ (step 9)
If you're considering the 6G mod, do it right and be sure you get your amps worth out of the change over![]()
No, you are talking about a 3G or some other alternator. The 6G doesn't require any grinding. It's smaller than a stock SC alternator. I just put one on last week.
I'm not sure what you are talking about here Mike. The output from the 6G is only 130 amps (some say its really about 110-120) but either way it's not going to overwhelm stock wiring. The stock alternator wire on an SC appears to be at least 6awg but might be 4awg already.
Guys, ... you are driving me nuts.
FYI - the car Dave was talking about is my car. I'll be happy to take pictures of the install if anyone is interested and post them up.
Now back to my search on fuel pump wiring upgrades.![]()
