dthompson
I will be selling my M5R2 transmission and related bits. Everything is still in the car, but I wanted to get this out there in case any of you guys were in the market for some of these parts.
Do you need a bunch of parts for your manual swap? Need a good shifting trans? I am selling these parts because I need a stronger transmission and I don't want to destroy this perfectly good transmission when I start to turn things up. I plan on pulling the transmission out late spring unless someone wants the transmission sooner.
M5R2 RKE: I refreshed this myself a few years ago using Mike Pucketts Carbon Fiber Blockers on 1-4. Shifts great. This transmission includes a B&M short throw shifter, and the slave cylinder that is installed (7-8 years old, but does not leak). I prefer not to separate unless the person who buys the transmission does not want the shifter. $800 with the shifter.
Centerforce DF clutch used: The pressure plate is about 7-8years old with ~5k miles on it. The disc is much newer with with approx 1k miles on it. $150
New spare slave cylinder, I bought a spare slave cylinder probably back in 2015 from NAPA. It doesnt have a box, but it has never been installed. $30
Clutch master, new and used: Original clutch master is what is in the car now. I also have a spare centric one. both for $30
Hydraulic line: Plastic OE style hydraulic line. Its a couple years old, I replaced the original one with this one as the clip at the slave gets crappy over time. This one works great and disconnects easily as it should. $20
Aluminum 3.5" drive shaft: $250
I also have a stock flywheel if someone is wanting to do a swap or just needs one $30
All prices are assuming you can pick up. I live in the Raleigh NC area. Pictures available upon request.
Thanks,
Derek
Thanks,
Derek
