90mm maf for 85mm
DirtySouthBird
I have a brand new 90mm lightning maf ...I would love to trade it for a 85mm maf..set up for 42lb injectors..let me know what you got....you can text..an send me pics..956-533-2189
XR7 Dave
Just so you know, you can get a MAF calibrated for 42's, but there is no real point in doing so since when you have 42lb injectors you also need a chip. A chip will make your 90mm Lmaf word perfectly with your car.
DirtySouthBird
I kinda want a c&l with sampling tube for 42's..think the 90mm maf is to big..an.im planning to add a 75mm tb..to it
XR7 Dave
85 is too big for a 75mm TB too. Do you have a 3.5" intake or 3.0"? A 76mm C&L will flow enough for well past the limits of the injectors and will match a 3.0 inch intake nicely. I have one which I would trade as long as you have a flange adapter and harness plug to go with your LMAF. The 80 and 85MM C&L's are not calibrated for 42lb injectors regardless of sample tube because they are just too different from stock to match up flow curves. ProM had a 75mm Bullet MAF that was calibrated for 42's but they aren't real common.
