having a hard time understanding how they replacement I have installed could go bad
Not just metal - there are two main steel parts, thick rings, inner/outer, joined by a layer of vulcanized rubber. Dorman has a reputation for being lowest quality - rubber not lasting I think is #1, #2 is bolts not holding up.
Some parts aren't worth the risk when it's a car you want to keep and depend on, but you said just to get a couple months out of it, so...
Otherwise, I think the question is how much risk an owner is willing to take with a suspected lower quality HB. It might be ok for a while, but a fail can be costly if it takes out other components, making it no bargain in the end.
How many times has the one in the photo been installed? Remind us why you removed it?
If you're certain the one installed now isn't chewing at the CKP sensor, then leave it and watch it like a hawk. If the one in the photo isn't that old (
not sure why you refer to it as 'stock/original'?), and hasn't been repeatedly swapped out, then consider re-using it. If you don't want to face risk at all, get the Dayco or BHJ. Just my $0.02 USD.
