One diagnostic tool that can used here, is the "search" feature. A code
This is from the Ford factory training manual. Hook up your voltmeter to a O2 sensor signal line, and with a steady idle, and cruise, it should the DC voltage should cycle back between around .2-.85 vdc, with an average close to 4.6 vdc. Give it 60-85+% throttle, and the O2 volts should be .8-.9 vdc, and hang there. If it goes low, especially under .5 volts, the fuel is lean. Pump, screen, filter, or injectors.
For a coil pack, read this to the end. The HEI tester is usually all you need.
172 | Lack of oxygen sensor (HO2S-1) switches, indicates lean (BANK#1) |
How to diagnose a faulty coil pack
I have been trying to troubleshoot a rich shuddering condition on my 92 supercoupe. After going through the process if eliminating several things it could be I suspected the coil pack could be the issue. I didn't have another extra unit laying around so I did some digging on how to bench test...
www.sccoa.com
