kool. im debating if i want another color now instead of clear
So I run 1 hose to my pcv valve and the other hose goes to the intake plenum where that hose that the pcv valve had attached to it went, and then what do I do with that little hose coming from the firewall that was attached to the original line that has the metal bundle going to the pcv valve and plenum.Correct, since our PCV valve plumbs to a port on the inlet plenum where it's not possible to create any positive pressure, the check valve isn't needed.
All you are doing is placing the oil separator inline between the PCV valve and whatever the PCV valve hose is currently attached to.So I run 1 hose to my pcv valve and the other hose goes to the intake plenum where that hose that the pcv valve had attached to it went, and then what do I do with that little hose coming from the firewall that was attached to the original line that has the metal bundle going to the pcv valve and plenum.
