Well folks, it's been almost 4 months and I'm happy to report the Sc finally has brakes. I drove it about 3 miles and they feel good, with quick engagement and good pedal feel. I was initially concerned that maybe they were dragging because at highway speeds I felt the car was kind of different in feel, sort of like "held back" a bit but...I think it might be more a factor of having been solely driving the GS400 for the last few months, with its extra gear, higher rear end ratio and more HP, and I need to get used to the lower rear geared, 4 speed auto, less HP SC again.
To be more certain, I jacked up the front wheels and they spin fine with no obvious dragging, and I jacked up both rear wheels and ran it in neutral and they spin without any rubbing sounds...so I will keep my eye on things and take a longer drive in the next few days and see if the fluid is getting hot or the rotors hotter than they should.
I was pretty sure i adjusted the booster screw correctly, but there's that little bit of uncertainty in everything I do.
Next, I have to take the car to the muffler shop and see if they can put that cat/pipe on the driver's side Y pipe....
Then paint/body work to repair all the damage the 'repair" shop did...
Slow climb back, but...even if i have some minor adjustments on the pedal rod, NO MORE ABS WOES!!!
WOOT!
BTW, I spent a total of $55 on the booster ($35) and master cylinder ($14.95+ shipping). But having brakes again= priceless.
