Anyone else had this problem?
T-bird Tim
I had a terrible vibration in the 94 SC that I bought recently. Everyone said it was the motor mounts. I replaced those and the tranny mount. Found out that it still had the vibration. Turned out to be that the right rear half shaft splines were severely worn. I mean to the point where they were almost smooth. Am having it changed out today and hopefully that fixes it. Just want to see if anyone else has ever had this issue.
Had the motor mouints, tranny mount and right rear half shaft replaced, still vibrates but not as bad. Definitely has better pick up with the new half shaft. In gear with the brake applied it vibrates rather noticeably but if I put it in neutral it's smooth. Any more ideas?
same for my 94, just recently replaced TPS & MAS & cleaned IAC still same problem & light comes on... gotta check code reader again, could be vacum leak, could be plugs/wires need to be replaced.... *sigh* could be something else...
Mine too. Check engine light comes and goes but when I take it to auto zone for the scan it always goes off right before I get there. I only got the CEL after I installed the CAI bigger MAFS and T-body. And I installed the proper sampling tube. I guess I finally got a problem no one on here can give any answers for. Never thought that would happen. :D
