I’m cleaning out the garage and have a bunch of stuff I am likely never going to use. Before I send it to the scrapyard, I figured I would see if anyone on here wants any of it. I have…
-One set of stock 94/95 SC heads, fully assembled with rocker arms.
-94/95 SC timing cover, with oil pump, oil cooler, and crank sensor
-Passenger side 94/95 SC exhaust manifold, EGR tube broken.
-4 engine oil dipstick tubes, 2 with dipsticks
-5 94/95 SC rod and piston assemblies in good condition
-Stock 89-93 SC MAF
-Stock SC oil pump
-SC tail lights, one set of early style and one set of late style. Both sets are all red. I only have the outer corner lights, not the ones on the trunklid
-Black early Thunderbird interior quarter panel trim pieces
-SC return plenum modified for use with aftermarket piping for FMIC setup
-2 SC fuel rails
-Various SC specific coolant pipes and hoses
-Early style AC/jackshaft bracket with good jackshaft bearing
-Stock jackshaft pulley
-Alternator/power steering accessory bracket
-Complete early SC engine from supercharger to oil pan, only missing intercooler. Includes complete wiring harness and computer. Removed from 90 SC, was going to do a swap into a V6 Mustang but the project never happened.
-Set of XR7 7-spoke wheels. No bends or curb rash, but wheels were repainted and some of the paint is starting to chip off, so could use to be sanded down and resprayed. Includes center caps
-2 aluminum SC spares with tires removed for use as lightweight front drag wheels.
-Stock 5-speed early model radiator and fan
-Complete AC system minus evaporator. Includes compressor, condenser, accumulator, lines, r134a fittings, and pressure switch on accumulator. Basically AC related under the hood
-2 alternators and one AC compressor, worked when removed, been sitting inside for years
If anyone wants anything, cover shipping and give me what you think is fair. The engine I won’t ship, but if you are within a few hours drive I can deliver it if you cover gas/tolls.
-Stock 89-93 SC MAF
-Stock SC oil pump
-2 SC fuel rails
