BE 2012 + Innovate wideband
Ifrit
Hey dumb question but does anyone have a way to data log the USB AFR output form innovate products? I have my wideband wired into my EGR and can data log like that but I am chasing gremlins in my logs and want to data log through the serial connection to BE. In BE it does detect my wideband and can read its output through serial and display it on the dashboard but I cannot figure out how to get BE to save it to the data log.
Thanks for any pointers.
Go to the datalog tab and make sure the wideband is checked in the PIDS display. I assume it is because its displayed on the dash. Its been too long since I've messed with BE I don't remember anything else.
Sorry in the delayed response been busy. Here is the magic in this, i combed the data log tab and it is not listed. I cannot for the life of me figure out how to add it to the list. If you have any idea I would be more than willing to try them.
I'm having the same problem on my new computer. I believe it as to do with logworks software. I can't get logworks to act right which I believe has to work to datalog the wideband into BE.
I have had no issues with my logworks software from what I can see. I find it super odd that I can read the wide band and setit to output on my dashboard but I cannot record it in my data logs. I have been searching for a solution but no luck.
Currently I can datalog it through analog but It is outputting weird values for me, at 11.8 on my gauge BE reports 11.50 at like 14.7 BE sees 15.0 and it does not seem consistent so I need to find another way to log it.
Figured out my issue, i was dumb and did not look through all of the log variables, so every was working correctly
