brake pedal
90scmxdream
Hi guys I have problems starting my car only after I depressed the brake many times the car start. Is there anyway to start the car without depressing the brake pedal?????. please help
jose
KMT
What year is your SC?
Some have a lockout that requires pressing and holding the brake pedal while starting.
My '90 with auto trans has this.
Ddubb
Your car has a Starter interrupt relay .. could be bad or sticking - sounds like the most likely part that is causing your issue, but I would need to verify it is getting power from the ignition switch and that it is relaying the power further down the line to the starter like in the thread KMT posted above. If you need a Ford OEM relay to swap in, or need more help to figure it out, let me know.
- Dan
