Selling whole or parting out if a good amount of parts is needed from someone. 1992 Thunderbird Super Coupe heavily built sadly the car has good Michigan rust on the underside and bad piston rings causing blowby and I do not feel like rebuilding it right now, just wanted to see if anyone is interested the car actually starts up and runs amazing other then the small drops of oil vapor coming out the dipstick. Clear coat fading throughout the whole paint job, interior is very clean. Car has a Art Carr Extreme Aod transmission and torque converter kit, this was a 10000$ Transmission kit that is rated for 900hp to the crank handmade with a 8.8 rear end with 3.90 gears. This transmission would be perfect for anyone having issues with their transmissions not holding up because one this will not break. All supercharger parts are ported, it’s got a beefed up intercooler, all smaller pulleys,basically every possible bolt on has been done, If this motor was rebuilt I would imagine it would make around 500hp, definitely one of the faster super coupes out there. I beat a 450hp twin turbo Grand Prix by almost a car length while my piston rings were bad lol. List of all modifications done are
3.8L supercharged engine
- Magnum Powers 's' ported Supercharger (18psi)
- Magnum Powers ported inlet plenum
- Magnum powers front mounted intercooler system
- Magnum powers 85mm throttle body
- Magnum powers 3.5" stainless intake tube and intercooler tubes
- Magnum powers raised sc top
- Magnum powers cold air intake divider kit with K&N 9" cone filter
- 15% supercharger pulley
- March 3 piece accessory underdrive pulley kit
- 42# high flow fuel injectors
- Custom Superchips computer chip
- Art Carr extreme AOD transmission and Torque converter kit
- Shorty Headers
- Catalytic Converters removed
- Custom exhaust with flowmaster 2.5" mufflers
- 3.90 Gears
- 2" lowering springs
New brakes pads rotors
New Transmission lines made and installed
Straightpiped exhaust w custom 2-1 y pipe and flowmaster installed with single exit
New Brake lines made and installed
New power steering lines
New valve cover gaskets
New pcv valve
Screaming demon performance coil pack
Live wires plug wires set
Pro m 92mm maf
- Shorty Headers
- 3.90 Gears
New pcv valve
Pro m 92mm maf
