DOUG H
High r.p.m.'s dont nessasarily cause a bearing to spin. It is caused by the rod or main bearing losing its cushion of oil between it & the crankshaft. The friction created by the spinning crank contacting the bearing insert causes them to weld to the crank & they spin in the connecting rod or the block( mains). The loss of the oil film (.001-.003 thick) can be from inability to maintain pressure-bad pump, lack of oil, poor quality/contaminated oil,wrong viscosity, worn bearings passing so much oil the pump cant keep up, oil filter bypass not working,etc.That is what I would do. Also, I have a question for you guy's. I see more than a few cases of spun bearings here. How do you do that? I've turned 5,500 rpm, by being slow on a shift, usually in 1st, or 2nd gear. But that is rare. Even at 5,000 rpm, it's not pulling, with a peak HP at 4,000. I got my white SC dirt cheap, because of a spun bearing.
The only time I've seen high r.p.m. cause oil starvation is when so much oil is pumped up to the lifters/rockers/ cyl. heads/ over head cams, etc., that it cant drain back down to the oil pan fast enough & the pump sucks it dry. This used to be common in olds 455's
