kpoindex08
Ok I have a slight problem with the 94 auto t-bird. I just can’t figure it out. I resolved the fuel pump issue and haven’t messed with it until today. I got excellent fuel pressure but I am not getting spark from the coil. Power is coming in the red/green wire while key is in the run position the 3 tan/stripe wires immediately get power also. With the key in the off position all 4 wires at the coil are ground. I replaced the crank sensor, cam sensor, coil, and harness with known good ones the ICM is the only factor I have not factored out that i know of.The tach is reading but it seems jumpy. BJH balancer is not wobbleing. I can’t seem to find a test procedure for the 94/95 ICM would someone happen to have some information they could share with me.
Thank you for your time!
kenton
kenton
