to those who have/do run electric water pumps, do you run it with restrictor plates or wide open ?
I am running a Meziere electric waterpump with no restrictors, no thermostat and Evans waterless coolant. It seems to work great; but I just recently started the car up and have not had it out on the road. Waiting on a nice day to take it out.
Mike
NPG+ or NPG-R?
Miller, If I remember right, you will need to block off the water-by-pass in
your thermostat housing. The plate that Gary kuhns designed and
had me machined. Had no hole machined for a fitting for the by-pass
hose coming from the thermostat housing.
i had the bypass (the hose that comes out of the T-stat housing) goin to the brass fitting on the inlet of the water pump. This is how gary had it hooked up also, but he didnt run heat.
i have thatbrass fitting into where the hose goes into tstat housing, and the strait part of it into where the oil warmer thing come up from underneeth... I figured that was my heat ?
Randy, thanks I saw that.. i only have water in it now so i didnt find any leaks and have a puddle of coolant on my floor, but i can already tell its going to be a major PITA getting the air out.. = /
when i loosen the screws in the back what should i knotice ?
