You are suppose to with the BHJ. The proper installation is to mic the crank snout and then mic the bore of the BHJ. Then shave the ID of the BHJ down to a certain diameter that is smaller than the crank snout measurement.
Check me on this BHJ measurement
Ok, checked the crank diameter, got 1.478. Checked the balancer and got 1.483. So my balancer is .005 bigger. Is that good. I think I read it has to be less than .015? The balancer slides on crank till it hits the key way. I think it needs to be pressed on after that. Also, I need to cut off 1/4...
www.sccoa.com
