HD Poly Motor Mounts
Chuck, I just made an effort to find my mounts. I can't get to them right now as everything is blocked in. Maybe someone else can give you some dimensions on the 93 parts. In a couple weeks I'll have time to take out a bunch of boxes and stuff and then I should be able to dig them out as I'll be starting assembly of my motor.
Just let me know.
Based on Ed's info, it looks like we need 3 pieces. A driver side 93-95 mount, a pass side 92.5-93 mount and a pass side 94-95 mount.
With these, we will have the full range covered 89-95 (as well as the 5.0 cars)
Chuck,
What about a tranny mount? I just spent the last few days swapping out a trans. and that mount is just as pathetic or maybe worse than the motor mounts.
Auto tranny mount from trans to crossmember looks like this:
(Courtesy of MN12Performance, RIP.)
If I remember correctly the threaded part (covered in blue plastic) goes down into the crossmember and a nut screws on the end and then the two hole have bolts going through them into the actual tranny.
There are two different styles of mounts where the crossmember bolts to the unibody.
Gee...looks alot like something I've already done for a european application ;)
George, you got your samples correct?
Yeah...and it looks sorta like the one for the new mustang as well. I can send you mine for the 5 spd when I ship out the motor mounts next week. Just let me know.
Chris
Chris
That would work for me.
Just as a reference, is the portion opposite the stud accessible when the mount is bolted to the trans?
OK, I got some parts from seawalkersee...
He sent some 93 SC mounts and the pass side lower bracket is definitely different, but I can take care of that easily. I still need some 94-95 to compare.
As far as the trans mount he sent me. It is identical to that mount of mine for another application I have pictured. The only issue is this. I'm going to have to look into some other way to do the long bolt as I don't think the top would be accessible once the mount is installed, and it would be near impossible to tighten it once it was all buttoned up. I need to see some pics of the trans mount installed to see exactly how it's in there.
Anyone have any installed trans mount pics?
I believe 93 is same as 94/95..Mount change had something to do with the ABS change in 93
FAST ED can look up part numbers to see if they are same
Well I am really unsure..But I was under the impression the change was 93 and up...Alot of thinsg were changed in 93...
Someoen at Ford could easily cross reference
