dirtydog that is a good design im sure they stop movement fore and aft but im wondering what about side to side movement of the K-member ? that rear mount point would essentially be a pivot point for side to side movement as say the front left tire hits a bump it would pull the Kmember that way slightly throwing off the stability good for fore and aft though definetly...Also just wondering, it hasnt created any binding with the bolt facing up in the hole in the K-member also the plate inside? I'd be afraid of hitting a speed bump or pothole etc. to fast and having the front raise and drop hard and cracking the lower control arm...Not trying to shoot you down just interested ...an idea would be to have to of those subframe rear brackets side by side one in front of the other to eliminate the side to side movement,but that may bend the actual support tubing if its not thick enough
