ignition issue
tbirdtony
car is 93 manual and has been running good. its summer in fl. and i wanted to charge up the ac to make it more pleasant to drive. i was driving ac was putting out cold air when i heard a clicking or popping sound under the hood . i drove home and lifted the hood and it looks like my ac blew out some freon/oil out of the check valve on the compressor. anyway i cleaned up the engine bay and when i tried to start the car it would not start. cranks good but does not seem to be getting any fire. what the heck is going on.
DOUG H
Oil spraying back on to the coil or DIS module did something? I wouldn't think so, unless a lot got into the one of the plugs & thats causing a bad connection? More likely while you were cleaning it something became disconected or pulled out, since it ran & you were able to drive it home after the initial issue with the refridgerent/oil discharge
tbirdtony
thanks i will look closely at the wiring to see if all is intact
tbirdtony
ford power plus hooked me up with a new wireing harness and i installed it and is back to normal. just need to recharge ac system
