Question out to folks that have installed one of these…..how much of a gap is there between the end of the front cover’s ‘pointer’ and the backside of the damper on your set-up? I seem to recall the OEM damper was within 1/32” but my BHJ is more than that (will edit post with actual amount here shortly). I didn’t think too much of it as the crank position sensor is centered over the damper’s trigger ring, but I did not use anti-seize on the hub and car cranks but is still not starting/firing, so hmmm.
