Tim Groth
Figured I'd ask here first before I pull the dash and add more work than I want. I've pulled several dashes so its not really that daunting but if I can avoid doing so and save time be worth it.
Some while ago the yellow vacuum hose was pulled off the blend door actuator on my 95. I believe a radio install somehow snagged the hose, and the tension pulled it from the inner working of the hvac box. Because of this the heating and air only blow from either the defrost/foot setting. Now that i have my car back after a long process of repairs I'm fixing all the other items that can't be seen on the surface.
I've attached the schematics from the repair manual. The yellow hose was dangling freely on the drivers side of the dash. So I'm assuming the attachment is drivers side.
Is dash removal avoidable or no way around this.
-Tim
-Tim
