ISO 1990 Super Coupe 35th anniversary
jasonlewis52
Must be a 5 speed. Prefer low miles, or at least excellent condition. Sunroof is a plus. Im in NC but will travel for the right car. Thanks!
jasonlewis52
Thanks for passing this along. I did see that one. I might consider an auto if I just cant find a manual but it has to be mint. This one needs some love.
Allen R.
M
5 minutes ago
to learn and share , My 35 th 5 spd. has many mods , mag. port ll charger and plenum , 85 mm T.B. , 76 Maf , Cold Air , Raised Top Hat , Mag. InterCooler , Kooks Mid length headers , custom home exhaust ( that dreaded drone ) , Screamin Demon pack , 255 l / hr fuel pump , Adj. pressure reg. , 38 # injectors , BCH Alum. pulleys , 10 % O.D. , 2 piece fly wheel , 6 puck clutch , half the poly bushings are done , Tokiko adj. shocks , Custom fiberglass window vents , 4 " fiberglass cowl hood , IRS brace yet to be installed , Roller rockers yet to be installed , D-Pic & A.F pillar mounted , Custom Audio , Eclipse Touch Deck and Parametric E.Q. , 32 MIPs' Processor , , Triple Infinity amps , Custom molded fiberglass sub boxes w/ Infinity 12 s' Perfects , Custom Aluminum Amp Rack..rear deck mounted . Scales in @ 4180 lbs. w/ driver. Best of 13.1 QT , 101.8 MPH . ... Dang ! Dropped a rod !!! would like to talk to Dave about a 4.2
jasonlewis52
Wow! That thing must be a blast. Sounds a little like my SVO mustang build. Deeply ported head, cam, gutted upper intake, ported lower. Cobra IRS rear, full max motorsports front kit. Cobra brake upgrade. Standalone microsquirt tuned for E85. Need to upgrade my injectors still. 1300cc are hitting almost 100% duty cycle. Havent dyno'd this build but the last motor made 345hp/389 tq on pump gas and 23 psi. Should be well north of 400 now.
Bosch
Hi Jason, I have a 5 speed anniversary in "decent" condition, high mileage but the motor's been fully rebuilt. Check out my post in the "cars for sale" subforum for pictures if you're interested. Located in Colorado.
jasonlewis52
Thanks everyone. I was able to find a 13k miles 5 speed Anniversary Car. I pick it up at the end of the month. Super excited to get my hands on it.
