Making room in my storage, few SC parts
TBirdSC89
Hey everyone. I got a bit of work to do on my Supercoupe but space in my storage is quite limited. All of these parts came off my previous SC's and have been stored in plastic totes. Let me know what you think they are worth. Figured I'd try selling to other SC owners and not on other sites.
- engine block (disassembled) from '92. Transmission automatic. Assuming these can't be shipped
-Complete master cylinder from '89- the system had hard to no brakes if I remember, accumulator might be bad? Extra reservoir I can throw in with it.
- I have another complete early model master cylinder and reservoir I was hoping to install on daily SC since a completely different set up was installed, but maybe I'll let it go for the right price and install one later. Car is just a pain to drive with the steering and brake line hooked up together (not my doing).
-2 oil pans with sensors still on. Early model.
-2 pairs of SC heads, early model.
-3 water pump pulleys, 2 balancer pulleys 1 jackshaft pulley.
-3 harmonic balancers. 1 has a bolt broke into where the balancer bolts in. One looks good. One has a little surface chipped off. The 2 might be garbage so I might toss out those.
-2 intake manifolds, 1 has fuel rail, stock injectors and wiring around the rail. Early model.
-exhaust manifolds for passenger and driver side.
-2 starters.
-a couple ecu's. 1 for 89 automatic, the other I believe my old '92 automatic but both automatics.
- stock subwoofer with stock amp.
- crankshaft from '92. 2 camshafts early model.
- rear lights complete from '92. Light scratches.
- pulley bracket assemblies for driver and passenger side. I believe that's what they are called.
- stock gauge cluster, close to 200k.
Complete.
- egr line and rubber hose.
- 2 evo sensors. I would replace seals before install.
- door panels for driver and passenger, tan color excellent shape.
- 3 crankshaft position sensors. I know 1 is bad, I haven't tested the other 2.
- 2 extra windshield mirrors. With lights.
- I'll update this as I go cause I know I'm missing some items, I have plenty of pictures too I'll be uploading, I can also send any pics at request. Shoot me your best offer for any parts, I'm not look to make a killing off these.
You can email me here or @ thunderbirdsc93@protonmail.com.
Ryan H.
TBirdSC89
I'm resizing the pictures I took of my parts and getting them on here. I thought it was because I forgot to renew my subscription (just got it renewed)
TBirdSC89
Both sets of heads of a '89 and '92 Supercoupes
TBirdSC89
Gauge cluster, evos, amp and sub, panels,
TBirdSC89
egr, lights, mirrors, climate control
TBirdSC89
Intake manifolds, lights, crank sensors, balancers, ams
TBirdSC89
2nd oil pan, pulley assembly, master cylinder with reservoir
TBirdSC89
How much for rear corner all red 92 n up? Do any of the trunk leds work? I need a driver's side 92 n up shipped to ny.
I will check on the trunk leds, are you talking about both the driver and passenger brake lights and the lights on the trunk? Just making sure I'm looking at the parts you're seeking
Ryan
TBirdSC89
I will check here in a couple hours, last time the leds were on the car they worked, but I'll get the lights and get better pics of them too
Hi i need the passenger rear corner all red, driver side trunk led.
I got better pics and looked closer at them, I'm gonna need to do a little wet sanding on them and polish before hand, they're a little too scratched up for my liking. I've had them for about 8 years now stored and with moving about a few times probably got dinged a little. Nothing broken on them, just scratched. I use to do body work so not an issue for me to do, I got pics here attached. I'll find a way to see if the led's work on the drivers side, but I'm wondering about the dark spot on the left part of the led in the pic..I'll test it out
