phils89sc
Since I bought my 15K mile LX last year, the power seats on both sides, primarily front to back, barely work. The only way to get the front to back to work, and that only happens when you have the seat height almost all the way up, is to get the height right, then it will move forward and backwards, that is until it gets to a point, then it grinds to a halt. If you wait a minute or so and try again, it will move a bit, rinse and repeat. The passenger side does the same thing.
So, today I decided to see what I could do. I took out both seats and started with the driver side. I flipped it over and proceeded to take the motors out. When I did this, what immediately jumped out at me was the condition of the rotors (commutator) where the brushes make contact..Looks very nasty, like grease or something got into it.
So I cleaned all three of them up and used very fine (400 grit) sand paper to freshen up the surface.
I also found that same goop on the brushes
I cleaned up the brushes as well, which really didn't look too bad.. Here is the after pic..
So, after all of this, and lubing the tracks, front to back, the problem was only marginally better, and by that, I mean barely. I thought I would have better luck on the passenger side, so I took it all apart, to find it a lot cleaner, no grease buildup or anything. The rotor surfaces (commutator) where the brushes touch were not as bad as the other, but still had some buildup.
I cleaned all of this up, but during reassembly, I dropped the brush holder and one of the stupid bushings escaped. I think I heard it actually say "Wheeeeeee, I am free!!!!!" when I dropped it as I could not find it after that! Maybe tomorrow.
In an attempt to maybe get the passenger seat back in the car tonight, I went to my 95 SC seats, the driver side, which are in my carport. I wanted to take the motors out and put them in the passenger seat. Well, this proved to be and exercise in futility!! After all of the cleaning of the SC motors, I find that they are different, ever so slightly. It seems that the shaft is slightly larger on the 95 SC, or maybe in the 95's in general, for the rotors.
Anyway, after all of this, I am still stumped as to why these motors have issues. They are so basic, and I can assume that at some point, they worked ok. I did notice something that may cause the weakness in these motors...The brushes... I didn't get a pic, but noticed on my driver seat that the brushes were not contacting the commutator very well. I would say that only about 60 percent of the brush surface was actually making contact with the commutator. Could this be a part of the problem? If the brush is not making full contact, could it cause the loss of power and torque in the seats?
I may, in the coming weeks, actually take apart the gearbox assembly to see if there is a problem in there... If Ford used the same practices on the seat motors as they did in their power windows motors, plastic gears and such could be disintegrated in the gear box. I wouldn't put it past them...
Any thoughts, theories or other comments are welcome!
Thanks,
Phil
Thanks,
Phil
