Sleeperdude97
I'm currently working on a 1989 ford thunderbird super coupe, and I need assistance with the front crankshaft seal. I was advised to just remove the seal with a flat head, clean the area and pop the new one in. When removing the seal all that came out was a brown rubber ring and a metal spring band and when searching for a new seal at my local parts store all the ones they had have a big metal piece that that goes around the rubber ring and spring band. even when searching the internet the only ones I see have that metal cover.
I would love to know if i did something wrong when removing the seal. I seen somewhere that you need to remove the timing cover to replace the front seal but the vehicle he was demonstrating the procedure with was not the same. So I didn't think it was valid.
Thank you so much, and god bless!!
