Make sure the fork tings are parallel, (flat), to the needle hub. Pad and shim the back of the fork where it lays on the instrument face, to achieve this. On the GM instruments, I would twist the needle past the stop, to crack them loose, before pulling. A bit risky, though. Do you have a speedometer repair shop in your area? Might be the safest way.
