sdw
My '91 5-speed died when going over a speed bump.
I have looked for a connector that came apart but have found nothing. I have spark, and fuel but the noid light did not flash when I checked the injectors.
I changed the crank sensor to one of my spares but no change. Changed the IRCM to a known good one, no change.
The car is modified and has a BHJ balancer and a QH chip, etc, etc.
I am not sure where to look now.
My grounds are good including the the one at the back of the drivers side head.
Is there a way to test the EEC?
There is one connector under the car attached to the transmission support that is melted from where it must have hit the exhaust. But the EVTM and wiring diagram has no info on it. My EVTM is at my garage so I can't give the page number but if you find where the two connectors go into the transmission you will see it pictured attached to the tranny support bracket. The connector has an end plug on it, but I have no idea what it is for.
Any suggestions would be appreciated.
Sean
Sean
