Odometer repair info...
Kit Sullivan
My SC had the same odometer problem that a lot do: The crap-tastic gears that Ford installed at the factory crumbled and made the odometer inoperable.
There is a guy named Mike White here in orlando that can fix 'em up quick!
He works at 'JC Auto Air', also known as 'Ice Cold Air'.
The info is:
1526 E. Colonial Drive (corner of Ferncreek)
Orlando, Fl 32803
(407) 896-4661
He charges $90 to repair a loose unit, and $175 to R&R the whole deal. Takes about an hour at the most.
So far I've put a few hundered miles on it and its working great!
Cobra85
Or if you're mechanically inclined, you can purchase the gear for $27.00 and do it your self.
This is what I did and repaired two speedo's for $50.00.
