Those things have to run like Fred Flintstone wheels.20's are edgy which is why everyone is running them. Definitely a lot cheaper, but ride is a little rough and wheels are pretty heavy.
Ricardo what do you mean by trembling?
I didnt see you asked. The car will wander and follow ruts and road imperfections on the highway at higher speeds. It can be alliviated with different alignment specs. You might not experince it but its a side effect of wide front tires. But it will feel more controlled and handle better during hard corners.
More to think about. Great. It's interesting to see the three different takes as to what constitutes a good fit.
Working with Fast Ed on the subject here is his take..
19" Combo 4....
Front 19 x 8.5 w/ 255/40 @ 35MM
Rear 19 x 9.5 w/ 275/35 @ 36MM
or
Rear 19 x 10 w/ 285/35 @ 40MM
Couple that with the fact that a 255 is taller than a 275,
It's not trembling, it's called trammeling and it refers as Ricardo said to where the wide tires will bite alternately on the inside and then the outside edge of the tire and pull the car around one way or the other depending on road conditions.
When a tire is wider than the rim, then that accentuates the problem.
Just for completeness, you mean his 255/40 has a taller sidewall than his 275/35 would have, by about 5mm, right?
RwP
I think you should go 255/40/19 in the front with a 9 et32 and 285/35/19 in the back with a 10 et35.
Thats getting risky even with the fender roll. But should look pretty agressive.
Dave I just purchased a 1992 SC and want to do 19” wheels 8.5” front and 9.5” back on it looking for an euro look can you please confirm the offsets? And suggested tire size etc ?If you step down to a 9.5" wheel then offset will drop to 36mm allowing you to split the difference and keep the tire in the same spot.
Which tire you use depends on how you want them to fit the rims. If you want a pulled look like Micah, then you'll want the 275 on a 10, and might even want the 245 on a 9. But, if you want the tire to be square against the rim like Ed's, then you will need to do the 8.5/9.5 wheel size.
Sorry I did the math and fitments a long time ago. I don't remember anymore enough to be able to help you.Dave I just purchased a 1992 SC and want to do 19” wheels 8.5” front and 9.5” back on it looking for an euro look can you please confirm the offsets? And suggested tire size etc ?
These seem to fit?My 9" +35 work well all around.
