Powder Coating Safety
Makes sense.
Oh yeah, and whats gonna blow up if you don't have a booth?
Powder coatings are "organic" in nature and, as susch, will combust if mixed with the right amount of air. The same thing applies to any organic dust, such as baking flour, sugar, etc. I am sure you have heard of tragic cases where a sugar mill or flour mill had an explosion.
Well powder coating materials are just as dangerous! Believe me, as I have investgated numerous powder coating lines that had fires and explosions, some of which had fatalities!
The risk with powder coating is dramitically lower than using solvent type liquid paints (i.e. laquers, etc.). However, that does not mean that they are not dangerous in their own right.
Powder coatings will not combust (burn) in the container as there is too much powder (fuel) and not enough air.
Same goes for the opposite condition, where a small amount of powder is mixed with a lot of air, the powder will not combust either.
The problem occurs when powder coatings are atomized with just the right amount of air. This "just-right" mixture is between the "lower explosion limit" (LEL) and the "maximum explosion limit" (MEL) and is often the exact mixture of powder and air at the gun applicator tip. If a source of ignition is present with this "perfect mixture" the powder cloud will ignite!
The result is a fireball that releases a tremendous amount of energy. If this energy is expended in a small area (what is called containment) the result is an explosion.
It is just like your SC engine works: gasoline is mixed with air and ignited in a contained area (the combustion chamber) and the resultant explosion sends the piston in the opposite direction. Ignite the same gasoline/air mixture in an open cup, and a fireball will happen, but no explosion since there is insufficient containment .
Most explosions happen when powder coating ungrounded (or improperly grounded) parts. The part will absorb some of the electrostatic energy used to charge the powder (so that it sticks to the part before curing). If the part is improperly grounded (more than one megohm = one million ohms resistance), the part will eventually become saturated with electrostatic energy and discharge to the closest ground (typically the gun tip). This results in an arc (ignition source) much like when you discharge static electricity in the wintertime after shuffleing your feet on a carpet and touch the light switch. The ignition source and the powder/air cloud cause a fireball at the end of the gun, the person spraying the powder usually screams and drops the gun, and the fire goes out harmlessly as the gun trigger is released stopping the power/air from fueling the fire. This event usually requires a change of clothes for the powder sprayer, at least their pants anyways!!!
However, if the person has been spraying a lot of powder in an enclosed garage, without ventilation, and there is a large cloud of power, then the next sound they hear is St. Peter asking them what they did back on earth to get into Heaven! The large powder cloud provides a significant energy source or fuel and air and the garage provides the containment...a very bad combination. The energy released from such an explosion is awesome. I have seen 40 feet of cinderblock wall moved 20 feet in a powder explosion!
Now that I scared the Sh-t out of you, it is time to bring you back to reality.
Powder coating is the safest method of painting, except for using laytex paint and a brush. Follow these important rules for safe powder coating:
1. Spray powder coatings in a powder coating booth that is designed with proper airflow. This ensures that there is not enough powder and too much air to have a combustion fireball (except right at the gun tip).
2. Always coat parts that are properly grounded. Use a ground wire attached to an electrical ground or cold water pipe at one end and attached to the part at the other end.
3. Eliminate all sources of ignition during spray operations. No smoking, no welding, no grinding, etc.
4. Cover all electrical devices within five feet of the spray area with air tight bags. Actually code requirements call for "dust tight explosion proof" electrical devices in this area, but they are very expensive.
5. Always wear a dust mask and safety glasses to protect your health when powder coating.
