Powdercoating Stripper???
Big_Fat_N_Black
I have seen certain brand aircraft quality pait strippers mentioned on here in the past that will supossedly remove the powdercoating from my IC tubes. What is it/they called???
Thanks
CeD
SCrazy
I used some stuff from Eastwood Company that worked pretty well. Need 3-4 coats in really tough area and it definately helps if you seal the part in the plastic bag a leave it in the sun.
On the parts where the casting is extremely rough underneath you may have to use a 60-80 grit grinding disk.
Have Fun
