Radiator fan not turning on
SC1day
So... I just replaced the radiator fan because the low speed didn't work. After I put it in I tested it with the obd1 and both speeds worked. Took it for a rest drive and the low speed didn't come on, but high speed did. Any ideas?
DOUG H
Since you were able to turn low on with the scan tool, that leads me to believe the IRCM, fan motor & associated wiring is good & that the ecm is able to control the relay's in the IRCM. Possibly ecm is not getting correct signal from coolant temp sensor? Does the your A/C system still work & does the low speed come on with it? Do you know what temp the high speed is coming on at-low speed temp 195? or high speed 210?
KMT
When you say 'replaced', was that with another OE SC fan? What happened that you needed to find a replacement?
Which year SC do you own? Stock?
SC1day
So I replaced the last one because the low speed didn't work. I tested it. I replaced it with an OE. It's a 90 with bolt ons.
