Rebuilt Engine 1994 SC
Someone posted about Mabbco Motors in Tyler Texas having short & long blocks( no core required) available.
Somebody else suggested Supercoupe unlimited. Possibly someone in your area can rebuild youe excisting unit?
Any recommendations on sourcing for a rebuilt 1994 SC engine or perhaps a used engine? Thanks!
I have no knowledge on current sources for a 'rebuilt' SC engine. I do have an original and complete 94 SC Auto engine sitting indoors on an engine stand and sealed with layered,large trash bags. It came out of my Teal '94 SC. I dropped in another motor in the car with forged pistons, etc...
Normally I hoard anything for an SC, but it's getting time to begin unloading parts and maybe a pair of fine running SCs next spring.
What the previous owner, older gentleman, misdiagnosed as a rod-knock turned out to be two broken Harmonic balancer pulley bolts which allowed the pulley to 'knock-knock' on the HB surface itself with every revolution. Since I was not going to use this engine (149 K miles), I pulled the oil pan off to be sure and examined all 6 rod bearing pairs. They all look normal but for the usual wear on the top half for a supercharged motor with high miles. The crankshaft looks great too. Everything else appeared normal and I have pictures of all 6 rod bearing pairs. I did NOT pull the heads or the int. manifold. I replaced all rod bearings with Clevite 77 STD size and spec'd the clearances. All properly pre-lubed. The reciprocating mass spins effortlessly... with the spark plugs removed of course. If interested PM me and I can send you pictures of the motor?
