Shaking bad
mikes95sc
Just put new transmission in prier to that car ran beautiful replaced wheel bearing b a ck but have noise underneath and vibration bad through entire car any suggestions abs ND brake light is on
Since d/shaft was out to replace tranny, that would be my 1st check. Loose, mounting flange surface at diff not clean, bent, joints, etc.
Trans mounts, trans to engine loose or not lined up, if 5 spd was clutch out, if auto flex to converter?
Both brake warning lights on would be a seperate issue & lot's of possibility's. Follow a proper diagnostic procedure
Possibly drive shaft out of phase? Was the slip joint pulled apart? If so it could be out of alignment causing non-uniform velocity and in turn vibration
i would say its gonna either be something to do with trans mount. drive shaft or wheel bearing (something not tight when replacing it)
He placed a add looking for a trans mount, so I'll assume that is/was the issue.
Although no reply in this post.
The issue was worn out tans mount so replaced all bushing around mount and bracket thanks everyone she riding know
