The balancer was actually loose and resting on the center of the crank, which is why I figured the sleeve broke. Thankfully it appears to have given out when I hit the key to start it up and it didn't hit the crank sensor. From what I can see it's undamaged so the super coupe gods are blessing me there.. If I could only find a new balancer I think I'd be set. I am curious to know if you Hagee any tips on how to keep that crank from turning when I try to extract the broken piece of the bolt...You said the belt fell off, so the balancer must already be most of the way off.
Just use a harmonic balancer puller to get it rest of the way. If it didnt fall off the sensor likely is o.k.
Use a left hand drill and bit and it usually just turns right out easily, a bit half the size of the broken bolt, I raised the car and went underneath. I think I removed the rad fanThe balancer was actually loose and resting on the center of the crank, which is why I figured the sleeve broke. Thankfully it appears to have given out when I hit the key to start it up and it didn't hit the crank sensor. From what I can see it's undamaged so the super coupe gods are blessing me there.. If I could only find a new balancer I think I'd be set. I am curious to know if you Hagee any tips on how to keep that crank from turning when I try to extract the broken piece of the bolt...
Also, I would like to say that I really appreciate all of your advise. It's been very helpful.
Yeah, I pulled the fan too. But the crank turns when I try to extract the bolt piece. How scan I immobilize th so I get enough pressure to turn out the stud?Use a left hand drill and bit and it usually just turns right out easily, a bit half the size of the broken bolt, I raised the car and went underneath. I think I removed the rad fan
Wow, it must be really jammed if it turns the crank? Wonder if its bottomed out in the crank-too long/wrong washer? May have to remove starter & jam ring gear if auto trans or just put in 4th gear if manual.
Auto. So I have to wedge the flywheel or something, right? Isn't there a cover panel at the bottom of the transfer.case I could.remove and then lock it down with a vise grip?Wow, it must be really jammed if it turns the crank? Wonder if its bottomed out in the crank-too long/wrong washer? May have to remove starter & jam ring gear if auto trans or just put in 4th gear if manual.
Crank shouldn't be turning, takes a lot to turn that especially with just a drill bitYeah, I pulled the fan too. But the crank turns when I try to extract the bolt piece. How scan I immobilize th so I get enough pressure to turn out the stud?
Now you are trying to buy another complete engine? For another car/project you have or you found more serious damage?Yeah, I pulled the fan too. But the crank turns when I try to extract the bolt piece. How scan I immobilize th so I get enough pressure to turn out the stud?
