Shop Purge
jco1385
I have an absurd amount of MN12 stuff in my shop. It's time to thin the hoard. If you're local and want to take a bunch of stuff - I will hook you up.
This is nowhere near everything. If you need something and don't see it, please ask. Prices will be PLUS actual shipping.
Various SC side skirt pieces. White/Silver/Red. There is enough here to complete a car plus an extra set of door pieces. There are 2 sets (plus a few) of the clips to hold the door pieces on. There is a very rusty set of the steel mounting rails that would be a decent pattern to make another set.
Everything in the picture: $150
Complete set (6 pieces, door clips, mounting rails) : $125
Door pieces with clips: $50
Eibach 3524 1.5" lowering springs - used : $100
1989-1993 center console lid: $10 each
1989-1993 center console cassette tray and rubber mat: $5
M5R2 stock shifter parts: $5
'Cold Air Intake' airbox for a cone filter (This mounts in place of the OEM airbox to create a wall between the engine bay and air filter. I never used it) : $ -PENDING-
Fabric (felt?) dash mat for 1994-1997 - grey : $5
Random gauges and mounting brackets: $10
Ignition coil for 1989-1995 3.8L N/A (one stock, one Borg Warner Select) : $10 for both
Distributor cover for 3.8L or 5.0L - rubber : $5
FN10 trunk net: $5
Rear-view mirror with map lights and wiring harness (not auto-dimming) : $5
FN10 shock tower covers: $15
1989-1995 SC Auto Ride Control shock tower covers: $15
MN12 stock battery hold-down bolt: $2
1989-1995 OEM fog lights/brackets (no bulbs/wiring) : $50
OEM Premium Sound amplifier F4BF-18T806-AA : $20
IRS subframe bushings/cups - used (4 upper cups, 2 lower cups, 2 upper bushings, 2 lower bushings) : $30
1989-1993 interior door handles - chrome : $10
FN10 4.6L DOHC ignition coil covers: $10
4R70W MLPS sensors: $20 for all 3
1989-1995 SC Auto Ride Control shock actuators: $20 for all 5
Yellow fuel injectors - unknown condition (was told these are from a V8 SHO) : $10
Red fuel injectors - unknown condition (Supercoupe 30#): $30
Auto Meter 1385 Quartz clock - New-in-box (LINK) : $10
Chrome fanblade wheel hubcaps - set of 4 : $5
1989-1993 SC hubcaps: SOLD
1997 cupholder console top - black : $15
Dome light / sunroof switch - red : $5
Ignition control module (came from 1994 3.8L N/A car) : $10
SCUI hub-centric rings (needed to run re-drilled Cobra rear rotors on MN12 hubs) : $5
Various random suspension bolts: - Tell me what you need
SC brake pedal assembly for manual transmission swap: $75
SC clutch pedal assembly (both have undamaged pin for master cylinder - see pics): $225 each
Stainless 3/4" 36 spline to 3/4" DD steering joint with steel 3/4" DD rod (you will need to drill the rod for install - bolt shown not included) : $40
Stainless 3/4" 36 spline to 3/4" DD steering joint with stainless steel 3/4" DD rod (you will need to drill the rod for install - bolt shown not included) : $50
Walbro GSS340 255lph fuel pump - brand new in box (wiring harness and sock included) : $ -PENDING-
silvrbrd
how do I send a pm?
Interested in hub centric rings and MKviii rear knuckle torx bolts, 4 I hope, noticed in assorted hardware tins.
David Neibert
SCCoA Admin
how do I send a pm?
Just click on the person's name and click the "start conversation" tab. I don't think you need to be a dues paying member.
jco1385
Replied
how do I send a pm?
Replied over on TCCoA. Someone else asked about the torx bolts. The hub rings are available though. The bolts you see in the bucket are actually my spare set. I do have a pair of them I can sell but I understand you need 4 for a set. I bent the other two when I smacked the car hard into a curb.
I would be interested in the rearview mirror with map lights, battery hold down with bolt, and the cold air intake box.
I work in a machine shop and might be able to make exact copies.
Someone is ahead of you on all of this except the battery bolt. I do plan to trace and make some decent drawings of the air box parts so they can be reproduced. I got it from someone on this site. Apparently there was a run of these a long time ago.
jco1385
Not sure how to edit a post here...
Sorry for the delay guys, I've got a lot going on. I'm working on getting the requested items packed today. I'll try to get a second batch of stuff posted up soon. I have a very eclectic stash so please ask if you need something you don't see.
jco1385
Everything paid for should have been delivered over a week ago by now.
Guys, sorry I haven't gotten more stuff posted up. I'm in process of starting new employment and moving so I've been kinda scattered. The cost of shipping is ridiculous as well. I think I've decided that it's not really worth my time to list the smaller stuff. If there is someone semi-local that wants to make a sweet deal on a bunch of MN12 parts please contact me. I'll get around to posting some of the more desirable parts at some point, but a lot will just be tossed. Life sucks sometimes.
