It is going in with the exhaust. Also it is '92 and up.xr7rocket said:I see you have a 91. I would recommend switching to the 93 and later gas tank, because for sure you will not bend 3.5 pipe around the old style tank.
xr7rocket said:Realistically, 2.5's to 3.5 seems overkill to me.
Grims95SC said:I'd go dual in, dual out. Check the numbers for yourself, if you have a 3'' out, its a bottleneck. I'll be switching mine to 2/2 when I have $.
But if you're starting from scratch, why not do dual in/out? It'll cost about the same and you won't have that restriction, even if it is a minor one.David Neibert said:I've got the dual 2.5" to single 3" then dual 2.5" exhaust system on my car, and it's working fine for me.
Grims95SC said:But if you're starting from scratch, why not do dual in/out? It'll cost about the same and you won't have that restriction, even if it is a minor one.
Yea i don't know where i read 3.5", sorry.I think you might have read my first post wrong![]()
sail7seas said:I heard dual in - single out will DRONE at 1500 - 2500rpm ???![]()
vs
Dual in - dual out.
I got rid of the 'drone' using Borla mufflers.
(vs dynomax super turbos, I have a pair for sale if interested)
My theory is going to 'single out' is like blowing through a
toliet paper tube and creates a new funny hollow noise 'Drone'.
vs
Dual in - dual out.
W.T.F.? Ummmm, NO!!! It's NOT just about getting around the early gas tank with a custom, mandrel bent, exhaust pipe. A 3" center section is "mainly" for FLOW. Many Seriously Quick, Go-Fast-SC guys use a 2-1-2 with 3" center section. {Jump in here any time Uncle Dave}1owner89 said:The 3" middle pipe was mainly for people to route the pipe around the old style gastank.
