no164ford
I am starting to do a solid rear axle, sub frame work, roll cage in my car and plan to post info and links as I go or I will forget everything. I know there are a few threads on here about this now but I am going to try to do this set up a bit diffrent also try to save a few bucks while doing it. Hope this will help someone out some day.
Plans:
1). Solid rear the will handle 1.3 60's or better
2). Make the uni-body stronger to stop twisting and cracking/popping spot welds i have going on .
3). Adjustable suspension that I can set up for better launches.
4). To make the car safer in-case I crash.
5). Remove some weight.
I have started by deciding what rear to use. I found a 96 explorer with a D2 axle it has 4:10's trc-lok 31 spline axles with 3.25" axle tubes at the local u-pull for 150.00.
Here is some info on factory 8.8 rears. also a good link: http://www.therangerstation.com/tech_library/Explorer8_8.shtml
DOOR TAG CODES/ OPEN OR LIMITED SLIP/ MAX LOAD/ GEAR RATIO
Bronco II 42 Regular 2640 3.45
44 Regular 2640 3.73
47 Regular 2500 4.10
D2 Limited Slip 2500 3.45
D4 Limited Slip 2640 3.73
D7 Limited Slip 2500 4.10
Ranger 72 Regular 2200 3.08
74 Regular 2200 3.45
82 Regular 2700 3.08
84 Regular 2700 3.45
85 Regular 2750 3.55
86 Regular 2700 3.73
87 Regular 2700 4.10
96 Regular 3200 3.73
F4 Limited Slip 2700 3.45
F5 Limited Slip 2750 3.55
F6 Limited Slip 2700 3.73
F7 Limited Slip 2700 4.10
K6 Limited Slip 3200 4.10
Explorer 43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Ford 8.8 - Rear Cover Ford 8.8 - Bottom (Diff is upside down) Ford 8.8 - Disc Brakes
The Ford Explorer 8.8-Inch rear axle has found homes in numerous vehicles besides the Explorer. It has been swapped in to Ford Rangers, Bronco II's, Jeeps, Chevy S-10's and even some cars.
The 8.8-Inch axle used in the Explorer is highly desirable because it came with 31-spline axles over the typical 28-spline found in the Ranger version. There’s a 20-25 percent difference in strength between this Explorer 8.8 and the Ranger 8.8. The bigger 31-spline axle accounts for most of that, but the 3.25-inch tubes also help. The 1991-1994 versions had 10-Inch drum brakes and the 1995 and newer models come with disc brakes.
Not all Ford Rangers came with 8.8-Inch rears. The base rear end in the Ranger has been the Ford 7.5-Inch. When Ford introduced the 4.0 V-6 into the Ranger in 1990, it came with a 8.8-Inch, 28-spline rear axle. The Ford 7.5-Inch axle was standard on the non 4.0 V-6 models.
To this day, the Ranger can still be found with either the Ford 7.5 or 8.8 inch axles. The base model 8.8-inch axle is still a 28-spline, but the FX4's come with a 31-spline 8.8-Inch rear axle.
The majority of these axles came with 3.73 gears and a Traction-Lok differential. The Traction-Lok can work very well and almost like a full locker if you apply a little brake pressure with your left foot while accelerating with the right.
Axle Comparisons:
Here a list of how the Jeep Dana 35, Ford 7.5 and Ford Explorer 8.8 axles all measure up:
Measurement
Jeep Dana 35
Ford 7.5-Inch (Ranger) Ford Ranger 8.8-Inch Ford Explorer 8.8-Inch
Width Between Wheel Mounting Surfaces 60-1/2 inches
56-1/2 inches (1983-1992)
58-1/2 inches (1993-2009)
56-1/2 inches (1990-1992)
59-1/2 inches
Pinion Offset To Right Of Center 3/4 inches ? 2 inches 2 inches
Pinion Length, Tube Center To U-Joint Center 11-1/2 inches 11-5/8 inches 11-5/8 inches 11-5/8 inches
Pinion Height, U-Joint Center Below Tube Center 1-7/8 inches ? 1-7/8 inches 1-7/8 inches
Bottom Of Diff Housing Below Tube Center 5 inches 5 inches 5-3/4 inches 5-3/4 inches
Disc Brake Rotors N/A N/A N/A 11-1/4 x 7/16 inches
Brake Drums 9 inches 9 inches ? 10 inches
Drum brake shoes 9 x 2-1/2 inches ? ? 7-1/4 x 1-1/4 inches (e-brake)
Distance between spring perches (o/c) 40-1/5 inches 38-1/2 inches 38-1/2 inches 38-1/2 inches
Tube diameter 2-1/5 inches
2.80 inches (1983-2009)
3-1/4 inches (2010-2011)
2.80 inches (1990-2009)(Non-FX4)
3-1/4 inches (FX4 Models)
3.25 inches (Neck Down To 2-3/4 inches)
Axle shaft diameter 1.16 inches 27-spline 1.29 inches 28-spline 1.31 inches 31-spline
Replacing A Ford Ranger 7.5-Inch Axle With An Explorer 8.8-Inch Axle
Explorer 8.8 Facts:
Has 31-Spline Axle Shafts
Beefier 3.25-Inch Axle Tubes
10-Inch Drums From 1990-1994
1995+ Have Disc Brakes
Needs Shock Mounts Welded On
Needs Spring Perches Welded To Top Of Axle Tube
Most Have Limited-Slip (Traction Lok)
Same 5x4.5 Wheel Bolt Pattern As Ranger
Plans:
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
Axle Comparisons:
Measurement
Jeep Dana 35
59-1/2 inches
Explorer 8.8 Facts:
