Ddubb
So the overall idea is to compress the rubber isolator so the rear subframe doesnt have any flex ?? Sort of like adding a little more pre-load ?
Does cutting the lip off the isolator mount bring the rear subframe up a little bit ?? And does the plate mounted on the front sandwich between the body and subframe or is it only used as a rubber compressor between the washer and subframe?
Im just wondering how bad it would be to make the whole mount solid .. the mount must still have some flex, how do you get the right amount, not too stiff and not too loose to cause wheel hop ? Do the other suspension components take a little more wear and tear since the subframe mounts dont have the ability to absorb some of the shock ?
Manny you mentioned it had alot of road noise .. other than that, any other bad effects ? I dont mind much road noise. Im just wondering about stiffening the whole rear suspension and subframe. Would it be possible to make a circle cup or a cup with a plate that would mount up and around the subframe mount so it wouldnt be necessary to cut the mount itself ? Im trying to get some ideas here.
- Dan
- Dan
