Autolite copper 103's gapped to .040
watch that 10%. It makes alot of heat
Why 103,s? Its a shorter plug. Wouldn't it not get enough spark?
I use the NGK 7317.
i have a sc set up in my mustang. I have the app103 plugs(double platnum) gapped at .035" and am running about 10-11lbs of boost. At higher rpms 5100 + wot the car sputters like there is no spark. Runs fine under 5100 rpms. I also have a scremin demon coil and ford racing 9mm wires. Should i start with a new coil or try different spark plugs?
the a/f ratio is 10 somthing. however my buddy did the same swap with his car has the same tune and has the same a/f ratio as mine but dose not do it. I know before the swap (using the stock mustang plugs) no problems. would running a double platnum plug vs a copper plug cause this problem?
Yes.
Justin
Justin not doubting you, but could you explain what about the plugs would cause it?
Douglass
