Matt_aka_Dale
When driving at 44 mph (gps) the speedometer shows 26 mph. I do have the correct speed sensor gear on. I changed it back when I changed the wheels on the vehicle about 7+ years ago and the speedometer worked correctly up until recently. The Odometer and Trip are both working. I popped out the speedometer assembly and inspected it, but didn't see anything immediately wrong with it.
I've removed the VSS and inspected it, but I have not tested it in or out of the trans(checking it's output). The connector and harness underneath looked fine. There was some ATF in the connector(likely from the trans pan gasket seeping over time), but I cleaned it out from both the connector and the sensor and test drove after that. No change. I have checked the ATF level multiple times now and it is at the correct level.
I then replaced the current VSS with another same style Ford NOS one. It was not the exact part number(it was off by two letters. #E45F-9E731-AA vs. my current one #E9LF-9E731-AA). Once again there was no change.
I will say, leading up to this, the speedometer would show these wrong readings at random. I'd drive to work with it acting up and park it, then hours later, drive it home and it would be working correctly. Now it's just always showing a wrong speed. Whether it's off by about 6mph or 20mph.
After reading through a few past posts in the forum, one so far has given me more of a clue...or maybe even an answer. "The VSS; if one works, the signal is getting to the speedometer module. So there's a problem inside the module if one works and the other does not." Which, to me, sounds like I might need another speedometer.
Any words of wisdom or have I potentially figured it out?
