I've got one I just swapped out. I just went out there and if you turn the bearing housing (part that clips on) about 1/4 turn clockwise it pops right off. I always swap to a Timken bearing instead of the cheap one that comes on the slave.
Ok it’s not brute but does take some trick, when you rotate the plastic you hit a stop. Left or right. While pressing on the unit turn past the stops, and it will pop out. New one goes on easier, on the unknown bearing unit it was a bear to accomplish, the new timken style one was easier to remove and install. I was scared to turn it past the stops but that’s what releases the lock.
