Time to unload - IRCM, Gray Interior Parts, Lots of others
smms25
Email smms25@aol.com
Parts are also listed on SCCoA Facebook and Thunderbird Supercoupe Facebook Groups. Pictures are listed there. If you need pics, please check out those sites or email me. I have a ton of pictures.
IRCM P/N F1SF-12B577-AA NOTE: I did open this thing up to see inside. It would need to have silicone or bolted together. But it was tested with Rotunda IRCM tester and is working. $100
1993 Factory Service Manual - $20
Interior Parts for 93 SC 5-speed Opal Gray - sell all together for $200
NOS/NIB Passenger Trim Full Power - $60
Glove Box - latch needs replacement - $50
Gray Seat Belt Set - $100
Center Console with Ashtray and Lid (a little discoloration on side on console) - $125
Center Console Lid (Perfect Condition) - just lid, no bracket - $75
Center Console Lid (some discoloration) - lid and bracket - $50
Steering wheel with cruise control (slight drying/discoloration on top) - $85
Steering Column Trim - $30
Upper and lower fel-pro gasket set (Upper set is missing exhaust manifolds)(lower set is missing one of the rings - I am not sure which one so make sure to check the picture) - $60
2 different instrument cluster finishing bezels in black (1 with auto headlamp one without) - $25/ea
Lower Seat Panel Black - $20/ea side
Set of 4 Early Model Wheels and 4 center caps – refinished, very good condition $150
Door Lock Strike Plate Rebuild Kit - New in Package $15
Exhaust Manifolds 92-93 (2 sets) - $35/pair
Power window Motor (driver side) - $15
Radiator fan and shroud (MOTOR IS FRIED – But plug seems fine) - $30
Stock used Harmonic Balancers 28k and 60k miles on them - $20
Most any engine wiring harnesses, 5-speed flywheel, pulleys/idlers, etc.
Set of JBL subwoofer with bracket and amp - $50
Set of JBL sub, bracket and amp (one mounting tab is broken) - $30
smms25
Bump to the top:
Would take $350 for everything!
Located in North Atlanta. I could meet within an hour or two to save on shipping.
smms25
Updated list BUMP to the top (plus shipping): open to offers and will knock some bucks off if you get multiple parts
1993 Factory Service Manual - $12
Most any engine wiring harnesses, 5-speed flywheel, pulleys/idlers, etc. - MAKE AN OFFER (fuel injector harness and DIS harness are sold)
Upper and lower fel-pro gasket set (Upper set is missing exhaust manifolds)(lower set is missing one of the rings - I am not sure which one so make sure to check the picture) - $50
2 different instrument cluster finishing bezels in black (1 with auto headlamp one without) - $20/ea
Lower Seat Panel Black - $15/ea side
Set of 4 Early Model Wheels and 4 center caps – refinished, very good condition $125
Door Lock Strike Plate Rebuild Kit - New in Package $10
Exhaust Manifolds 92-93 (2 sets) - $25/pair
Power window Motor (driver side) - $10
Radiator fan and shroud (MOTOR IS FRIED – But plug seems fine) - $15
Stock used Harmonic Balancers 28k and 60k miles on them - $10 for both
Set of JBL sub, bracket and amp (one mounting tab is broken) - $30 - the foam is falling apart so the box may not be worth saving... will sell pieces separately
smms25
1993 Factory Service Manual - $10
Most any engine wiring harnesses, 5-speed flywheel, pulleys/idlers, etc. - MAKE AN OFFER (fuel injector harness and DIS harness are sold) - no harness over $50
2 different instrument cluster finishing bezels in black (1 with auto headlamp one without) - $10/ea (or $15 for both)
Set of 4 Early Model Wheels and 4 center caps – refinished, very good condition $125 (will ship)
Exhaust Manifolds 92-93 (2 sets) - $20/pair
smms25
$250 for it all + SHIPPING
$200 for it all if you pick up in Atlanta (N. Atlanta/Marietta/Roswell) area (zip 30062)
Most any engine wiring harnesses, 5-speed flywheel, pulleys/idlers, etc. - (fuel injector harness and DIS harness are sold) - no harness over $50
Gray Seat Belt Set
Set of JBL sub, bracket and amp (one mounting tab is broken) - the foam is falling apart so the box may not be worth saving... will sell pieces separately
SCRACING?
still available? ill take both. shipping to 02649?
wglenn15
I need front seats
wglenn15
Do you have front seats?
rjgraul
Not in gray. I have a full sunroof with glass and shade in black
Sorry for the delay - I do not check this often
How did you know I needed a gray one? :) I guess you want to see the whole works as a set? Asking price?
