Tons of parts for sale; lots of aftermarket go fast stuff
1FSTBRD
If anyone wants some pictures, I can post some. Right now, I'm just listing what I have. I'm parting out my SC as well, and the deadline is Friday.....it gets towed away for scrap. It's a white SC with very good grey interior with leather/ tweed seats. Before anyone asks, the cowl is cracked. :D The guys that I bought the car off had put an XR7 spoiler on it, painted white, if it's of any interest to anyone.
I can swing a deal and knock some of the price off if more items are being bought at once. I live in Canada, so shipping/ customs will inevitably cost more.
The textured finish performance stuff is influenced by what Larry Meaux has done on some of his race engines. You can read more about it in this article http://hotrodenginetech.com/pipemax-creator-larry-meaux-on-race-engine-head-porting/
--used Ford 36 lb injectors $60
--used Ford 30 lb injectors $60
--K&N panel filter for use with stock airbox $25
--ported/ textured lower intake manifold. Got very far in with various porting tools into almost all of the difficult to reach places. $60
--ported/ textured return plenum. Gasket matched the outlet $40
--triple wrapped intercooler return tube. One layer (against the tube) is rubber, the middle layer is reflective foil tape, and the outer layer is header wrap $60
--almost new Airtex/ Wells water pump (comes with gaskets) $25
--recently bought remanufactured/ tested ECU (has code of "X1A2") $75
--almost new Standard ignition switch $20
Various sensors and things (might throw some of these in for free if you buy some other things)
--used Ford mass air flow electronics (ie: black box on top of the MAF)
--used cam sensor alignment tool (OTC)
95sc2810
hi im interested in the blower and the injectors, and I'm not sure how to pm on here lol so if you could pm me id appreciate it
1FSTBRD
Requires minimum 10 posts....
Yup, looks like I can't PM 'ya.
I bought the blower/ plenum off a fellow member here a couple of years ago for about $300, it had the ported 75mm opening in the plenum. I had fully ported it myself (used lots of extension tools), and opened the already ported blower up more. Does $300 sound reasonable? The injectors were $355, bought a couple of months ago, does $200 sound reasonable? The pulley and belt, does $50 sound reasonable for both? $550 for all?
1FSTBRD
I'm not sure how many miles are on the blower (I had never got--nor asked--the mileage), but I've only driven mine in summer, and half a week to work and back. I'd say about 5-6 thousand kms that I've personally put on it. The rotors are in great shape. It was efficient enough in its output to run 15 psi and give tiremarks down the street like in my avatar, on 30 lb injectors (but with a double intercooler) and stock heads/ cam. When I took a look at the FelPro replacement head gaskets and the pistons, there wasn't even a hint of detonation or gasket failure. Imagine that. :D
I'll take some pictures of it in the next hour and post them here.
95sc2810
Sounds great man! Cant wait to see the pictures... I'll take a look at them and ill let you know. Id gladly do 350 for the blower and pulley. (maybe throw in the double ic) ;) lol thanks man
95sc2810
Im mostly interested in the blower,pulley, and ic. So I'm confident we can work out a deal. Seems fairly priced.
1FSTBRD
Apologies for the gasket maker still on the gasket surfaces--I literally took these off just a few hours ago.
Inlet into the intake plenum:
Blower outlet (you can see a little bit of the textured finish....hard to totally capture with the camera) and the rotors are in excellent shape:
Jb Welded part. Looks like a crack in there, but it's not....just where the JB Weld overlaps:
Someone had painted the intake plenum silver before I had got it:
Double intercooler with fan:
1FSTBRD
I have to go to work now, but after I get home, I'll figure out the shipping. It would be two packages.
DrFishbone
How much do you want for the:
1) QH?
2) DIS module?
3) Oil separator? Do you have a model # or picture?
4) Cam sensor?
5) TPS?
6) I'm looking for a 10% OD Blower pulley too....I know you said you'd like to keep complete though. If you'd reconsider, let me know.
1FSTBRD
1) QH?
2) DIS module?
4) Cam sensor?
5) TPS?
1) does $150 sound fair for the QH?
2) $25 for the dis with the bottle of compound?
3) $70 for the oil separator? It's for a Mustang, but it worked well on my SC. I mounted mine right by the front airbox (right next to the rad), but I had also removed my A/C. It also caught a lot of water vapour, too. I still have the box that it came in with the mounting hardware, in case you can figure out a better place to mount it
4) $10?
5) $10?
6) if the deal falls through with the blower, for sure.....I'll give you first crack at it
I'm still at work, and when I get home, i'll upload a picture of the Moroso and how I mounted mine.
