UHMW IRS Sub-Frame Mount Kits
DLF
OK, I think I can do this.
Interesting day. :cool:
Didn't break anything. :)
The sub-frame bolts came out, fairly easily, with a breaker bar. The front and rear bolts are the same.
There is a 70 degree taper on the bushings and in the sub-frame. My bushings are all still in pretty good shape. All the captured nuts in my frame are rust free and still green. :D
I believe that I have a design figured out, I'm just going to think about it a bit more. ;)
I'll make another post a little later this evening.
DLF
I've completed my initial design.
I'll be using 1 1/2" diameter 6061-T6 aluminum sleeves, 3.2" for the front and 3" for the rear. I'll have them Mil Spec hardcoated to protect against corrosion.
Each position will require both an upper and a lower 4" diameter UHMW bushing.
The stock steel lower mounting plates will be reused.
I'll have to buy about $200 of tooling to make these.
Material costs are estimated at $75.
I estimate that it will take me more than one, but less than two full days to make a complete set.
Bolts will not be included. My reasoning for this is that some, myself included, would be willing to pay the premium for the Ford bolts (assuming that they are still available, I'm checking that), while others would prefer a less expensive generic bolt. Also, depending upon the condition of yours, new bolts may not be required.
Initial pricing will be $400 shipped (lower 48).
I'll offer a discount of $50 for early adopters who prepay in full between now and March 31, 2010.
The first sets should be ready to ship within 3-4 weeks (turnaround time on the hardcoating is 7-10 days).
Who wants a set?
Regul8r
Can someone tell me what the "SPECIAL TOOL" is for?
I see the regular bolts that need to be unscrewed but what do you need the special tool for?
DLF
To actually pull the bushings out of the sub-frame.
Here's a picture.
DLF
The Special Tool in action. :cool:
WOW, Thumbnails are back! :D
XxSlowpokexX
There is a 20 degree taper on the bushings and in the sub-frame. My bushings are all still in pretty good shape. All the captured nuts in my frame are rust free and still green. :D
Do you plan on doing any welding to your subframe? Ive seen a few weld them up and add some support metal here and there
S_Mazza
This is a great new product and I am very interested. However, I have other fish to fry at present. (No Lent pun intended.) If and when I get my other car issues straightened out, there is a good chance that I will purchase a set of these.
Thanks for coming out with all these parts for the club. It's great to see someone with the required capabilities take enough interest to get tthe ball rolling for everyone.
DLF
No, and I don't see any reason to, none of the original welds appear to be flexing.
If I had 500+ RWHP, I might feel differently. ;)
DLF
Material and tooling has been ordered. :)
Stay tuned for updates. :cool:
Don't forget that the early adopter discount ends March 31st. ;)
DLF
FWIW, I decided to check with ARP to see if they had any Stainless 300 bolts in this size.
The good news is that they're are starting to make 12mm bolts. :)
The bad news is that the longest they're making is 100mm. :(
Duffy Floyd
SCCoA Lifetime Member
The "Special Tool" is used both for removing the stock bushings and also to install them. BTDT. I found a complete set of the OEM bushing for the 95 resto. Have a sandblasted, repainted sub-frame ready to go with the replacement bushings installed.
DLF
Here are some renderings of the bushing designs.
The first two pics are of the upper, the second two are of the lower.
DLF
Apparently, my earlier renderings confused some people.
Here are two more oriented as they will be when installed.
------Upper-----------Lower
DLF
I received the aluminum bar stock for the spacers today, so the machining starts tomorrow. :)
Crap! Looks like I won't get the UHMW until the 25th. :mad:
DLF
Machining the sleeves. Takes about 1/2 hour each to get them to this stage, and the diameters still need to be turned. Got another 8 to go in this batch, then they're off to be anodized. :)
Thomas A
Looks great! I hope to be able to purchase a full set of your products sometime this summer!
Thomas
