The news after my other post regarding the belt alignment with my alternator underive pulley, is that things got worse, even though I thought it was working out ok (got the belt riding better but that did not last). Shredded 2 ribs off my second serpentine belt, the pulley CLEARLY sticks out from about 3/16th to 1/4" more than the other pulleys in the belt loop...I spoke to Bryan and he noticed far too many alt shaft threads were sticking out from the nut in my pics, and that the clearance between the alt casing and the backside of the underdrive pulley Bill E sold me was way too much, as his stock pulley had about 1/16th in the same spot..he suspected there was a spacer behind it pushing it forward...he was right...but it gets worse.
Bryan came over today and helped me remove the underdrive pulley, and we indeed found the spacer pictured below was behind it. Problem is, the spacer moves the pulley too far out of position (forward) and if we take the spacer out, the underdrive pulley rubs on the front casing of the alt. It needs a spacer for sure, just NOT that one!
That cannot be the right spacer for this application, period.
Bill sold me these as "used" but I expected they would fit my application regardless, as he knew what it was going on.
Now I'm in a position where I either have to;
1) find the proper spacer for that pulley, if Bill even knows what the proper size is (I assume he knew the manufacturer, at least I hope so)
2) Have the spacer cut to proper size by a machine shop, or have them make one to specs, only I don't know the specs necessary or if a shop can figure it out based on the oem pulley setback.
I tried calling Bill yesterday but got his voice mail, will call again tomorrow...
Gone through 2 belts now, one a Gatorback, so it's getting expensive.
comments / advice?
Underdrive with spacer on it vs smaller oem pulley w/o spacer;
Underdrive pulley with spacer off vs oem pulley;
backsides of underdrive vs oem;
comments / advice?
