what is the normal amount of vacum our cars should be pulling ? assuming it is a good running motor with no vac. leaks. im getting about 19 inch. in park and about 16-17 inch. when in drive. this is at normal operating temp. 185-190. im suspecting my lower ic tube is the culprit. as i have gone through all the vac. lines behind the blower and plenum and they all look good. the reason why i think i have a vac. leak is because when i start it when it is cold it revs to about 1800-2000 rpm
