I had my stock fuel pump replaced a few years ago with a walbro 190. Its using stock harness, will the wires hold up or will the pump mess something up over time?
Did you switch to something different?Not a problem, I had that same pump for several years, then a 255 lph hi pressure for even more years on the stock wiring.
A few years back I had a gas leak from the fuel pump and had it replaced with a walbro 190 I purchased of lmr.com.Did you switch to something different?
Actually I was asking David if he switched to a something other than the walboro…I am about to replace my stock pump. I purchased the Wal 255 but doesn’t exactly knock my socks off.. I have aquarium pumps that look more impressive.A few years back I had a gas leak from the fuel pump and had it replaced with a walbro 190 I purchased of lmr.com.
