What do you think failed on my clutch?
Clutch Failure Component
  • Hydraulic Line
  • Slave Cylinder
  • Throw Out Bearing
Results are only viewable after voting.
decipha
Hopped in the '89 day before yesterday to move it around the yard for her bi-monthly startup and putt around (i.e. musical cars). In any case I got 3 pumps on the clutch pedal before it went limp and I lost the clutch. Checked the reservoir and she was bone dry.
In any case thought I'd make a poll to see what yall guess.
Winner gets nothing other than an 'at a boy.
Cracked resivor / hole in the line and slave you should see some wetness under the car try and follow it to the highest point as gravity tends to move things down so for example if where the line meets the slave there is a fairly large amount of fluid there it's probably coming from higher up and accumulating there basic go up till its dry if the hose is wet to the resivor then I'd think resivor does the pedal go to the floor and stay there or does it make any sort of attempt to return back
