MikeKanterakis
I did a search for this, but came up empty handed.
1990 Automatic, original head gaskets, 236,000 miles.
I'm replacing the head gaskets and am using 400 grit paper to clean / flatten the heads and the block (where the heads sit). Is 400 grit paper too rough or too fine?
I've heard in another post that you want to make a mirror finish. I've also read that you don't want a mirror finish...
So, i've sanded down the heads and the top of the block to the point where you can just see some of the "imprint" of the head gasket. Same on the block.
My question is, is this good enough, or do I want to rough up the surface a bit so that the gasket will "catch" better? or should I go for an even smoother finish?
BTW, my arms are ready to fall off.
Also, I originally notices some major streaks on the top of the block where it was initially machined by the factory. Now some of those streaks/creases led directly to the two chambers where the head gasket was starting to fail (splitting apart on the metal ring part). Now that I have sanded the block, those creases are barely there, and I have a nice smooth surface just around the cylinder where the metal ring on the head gasket will sit.
I've also noticed that the sand paper was getting dirty and fouled very quickly at first, but now that the block is 98% clean, the paper seems to just loose it's grit and not make any real difference to the "cleanness" of the block.
